Camber?
slight plug here but those of you interested in camber shims Regal auto are gonna have them at gti inters for sale this weekend to save you using washers :lol: if you're interested let me know and depending on demand i can let them know how many they need to take with them. 8-)
  • Replies 31
  • Views 3.7k
How easy is it to shim out the rear end i.e. how long would it take??
and a rough price dude?
there £20 for a pair and very easy to fit
i think phils got 1 set on there
il try get picks of mine with two shims each side
worth the money guys and hard to find normally so get them while you can
harv
You'll get through tyres a fair bit quicker mind you.
Do they do them for the Mk3? might solve my scrubbing issue.
easy as pie to fit lieterally just sit under the stub axel which is 4 bolts! yeh you'll go through tyres quicker but its not massively noticeable i haven't noticed any wear on mine. usually £20 for a pair but i'm not sure whether they're doing discount for the show but i'll find out! also pretty sure the ones i used on mine will fit a mk3 as i know the fit a wide variety of different cars
have you got a pic of like either the right or left half of the car from the back, so we can see the camber better
spoken to my man paul down there, he has reliably informed me they'll fit anything polo from a mk1 right through to a 9N3 gti :) and will be going for £15 on the day!
Good stuff mate, cheers for telling us!
PIMP AS HELL BONNET! :p :p :lol: as for the shims, i may be intrsted but wint be at any shows? will they be £15 still or back to normal prices.
they'll be back to £20 down to delivery!
Do i need longer bolts for my stub axel? How easy or hard is this to fit with drum brakes? Cheers mate.
nope i run standard bolts on the stub with 1 shim each side and its simple as with drums, whip off the actual drum so its just the bare workings of the brake on the back plate, undo the 4 bolts at the back and slide the shim up the back! hey presto
Thats what i like to here, now i just got to find them at Inters!
Oh and i posted a link to this on Polo3. :D
should be easy enough, from what paul tells me they're trackside. they'll have a reasonable sized stand with their mk5 on display running the new 400+bhp RSR lump!
Who do i contact to order mine mate ?
I have had a look on there website but i have been unable to find the said product .
Do you have any contact detail's ?
Do youi have to get lengthend handbrake cables made up ?
Steven
get on the phone to paul 02380 558636 and he'll be able to hook you up if you just tell him you're after camber shims for whatever car it is you need them for.
no need for lengthened handbrake cables either!
Cheers mate :thumbsup:
I'm thinking of getting some camber shims, on your first pic is that of the schmidts from behind with 185s
nope thats the works with the 195's
How much????
Solution......... buy 2 sets of cheapo feeler gauges, insert blades as required, if you have a camber gauge you can work out what sizes = what amount of camber.
How much????
Do you have lengthend handbrake cables or do you have handbrake cables at all as i have been told by some i might need them and others on here have said no i wont .
Dont want to order some iff i am going to have to get some custom length handbrake cables produced .
What Camber / Caster do you run on your track car too front and rear .
Stevie
