Camber?
How much????
Solution......... buy 2 sets of cheapo feeler gauges, insert blades as required, if you have a camber gauge you can work out what sizes = what amount of camber.
Do you have lengthend handbrake cables or do you have handbrake cables at all as i have been told by some i might need them and others on here have said no i wont .
Dont want to order some iff i am going to have to get some custom length handbrake cables produced .
What Camber / Caster do you run on your track car too front and rear .
Stevie
Standard cables no mods required, cant remember the front camber but it was as much as I can get on it with max castor, the rear is half a degree positive
  • Replies 31
  • Views 3.7k
ill definately take a set! ill be at inters!
Do these only fit the rear?
yeh on mk3's front camber is fixed unless you buy camber adjustable top mounts
Ok.
I'm still a bit confused as to how they fit though.. I'm using wobble bolts too (Mini wheels), would that be an issue?
nothing to do with wheel bolts, all to do with the 4 bolts that hold the stub axel on! it's really quite simple once you take the drum off it all makes sense!
Should be picking some up at Inters then :thumbsup:
