1.3 various bits gonig cheaps!
Coil £15 posted
Rocker gasket early type £3 posted
Brand new never used sump and gasket cost me around £30 will take £18 posted
Inlets with heaters from 2G will take £15 posted the pair
Bagpipe stat housing and elbow used for less than 50mi £10 posted
Mk3 alt mount £10 posted
Rear metal water pipe £7 posted
Cambelt cover £3 posted
Rocker cover requires blasting or whatnot.. rat look? £10 posted
Stat and hardly use rotor and dizzy cap bought on ebay but does not fit my late 1.3, £7 posted
Couple of brackets £1 each posted
Hedgehog heater £5 posted.
Or I will take £80 posted for EVERYTHING above to get it out the way (£25 off the total ;) )
cheers, Matt
  • Views 284
will tht stat housin fit a gt buddy? if so al have it
cheers gaz
I think it will.. only thing it may require is a couple of the pipes blocking off.. bolt in a bit of pipe jubileed in and jubileed on will do the job a good un :biggrin:
is the sump still available does this fit a 1.3 spi and would you take £15
yes it will fit, have checked on ETKA fits 91-94 polos as well.. will go to £16 and you got a deal posted.
