Bodywork Rust hole!!
Eeeek, this is not the original door for the car as it had the original red rather than the faded pink, so the last owner did a bodge job on getting a replacement door,
as i ran my finger along the top of the door to see how bad the rusting was my finger went straight through one patch!!! *DOH* :-(
As I'm a complelte newbie to car maintance, whats the best trick to patch this,
http://img388.imageshack.us/img388/2440/dsc00812hm0.jpg
http://img265.imageshack.us/img265/7560/dsc00811kk2.jpg
  • Replies 8
  • Views 1.6k
Wire brush back to good metal
Use a rust treatment
use mesh & filler from the inside
Rub down & paint
^^ WOAH PIKEY OR WHAT! that will last about a month! do it properly either get a new door or weld it up, check below thw window chanel too as it might be up there.
Will do, i did use a brush to clean off all the dead area and this is the final size of the damage. cant see it affecting anywhere else.
As its a replacement door anyway from the last owner its clearly a dodgy grab from a scrappy. The rest of the car and its original bodywork is rust free.
http://img108.imageshack.us/img108/8849/dsc00814sp8.jpg
Isnt it too small an area affected to worry about a new door? tbh it is only a mk3 and where its situated its purely cosmetic or am i wrong?
wouldnt even bother trying to weld that up much easier to grab a straight door from a breakers, if not fab up a piece of metal same shape as the mouldings, cut out, weld in, skim of filler and paint
just get another door on it
Well i couldnt see any easy way to weld it, or what to weld it too, so i went for the bodge job....
You're right though it really should have a new door but it can wait untill one turns up in good nick. *Completly lacking in decent scrappy near me*
Applied Filler to patch the holes.
http://img401.imageshack.us/img401/2372/dsc00826ox9.jpg
Applied Primer to protect from futher attack, just needs a colour match on the paint.
http://img441.imageshack.us/img441/3737/dsc00827zv1.jpg
id get a new door , coz i had i a big bit of rust on my wing on my polo i put my finger in it as well and i filled it full of fiber glass then filler i was going to weld it up , but i got told at work it will come back so i would jst get a new door m8
your gonna have a job getting a door that will match up to your red though mate.
Red mk3 is probably one of the most common Polos. So finding a replacement door shouldn't be hard.
