15 x 7 ATS Cups on a MK3 polo
I currently have 13's running 145/80/13's but have seen a set of 15 inch ATS Cups for cheap money running 205/55/15's
Any chance I can squeeze them on a Mk3 polo breadvan?
I also want to drop it a bit, probably only a subtle 40 or 60mm, will this make any difference?
  • Views 1.2k
tyres are way too big :-D
you're going to need some 165/55/15s maybe with plenty of stretch :) ? squeezing them onto a breadvan will be a task with a 60mm, its more than you think...
Edited by joeshaw123
Imposible with this tyre´s!
You can go on 7" wide rims, but thats hard, hard work, and its just possible it the Offset fits, and the rear axel is exactly centered!
I got 6,5 *15 ET38 with 195 45 15 with 60/40 Suspention on my Heck.
there´s just a little gap between the tire and the Arch on the left side. take a look.
cheers guys, I think i'll pass on those then.
Not so cheap if I have to fit 4 new tires.
