Rust.
I found abit of rust under my back arches on my 6n.
Anyone know how to get rid of this?
If so does it make a nice neet job?
to stop the rust spreading get some rust treatment asap...
you could alwasy sand it down then give it some rust treatment which u just apply with a paint brush then primer it and paint it with the right paint... which you could do yourself as its under the arch and no one will see it...
or the best and expensive way is goto a body shop
Just do it yourself. Get a wire bristle drill attachment, grind it all away then zinc primer it, followed by your paint. job done!
So you think i should should sand it down, primer it then paint it with a brush? I've got the exact same paint as the car colour. It doesnt look different at all.
I will try and get some pics up to what it looks like tomorro.
Thanks for the replys guys...Anymore more ideas?
Dont paint it with a brush :lol: just use a spray can. You should also use a bit o filler
With a spray can, would it look a different shade to the colour I've already got.
How much would going to body shop cost?
