Outer tca bushes
Is there any trick to fitting them as i've tried and they just won't push or even be hit in.
They just seem too big!
  • Views 1.3k
Bit of lube and a bench vice work wonders :-D
are youre tca arms oe or replacments??replacments can alter in size
oe as far as I know.
Will give the vice a go tomorrow but 2 be honest not sure its gonna work.
Would it be ok to file a little out of tca?
bump
Hello!
I had a set of these - fitted them and thought - they stick out / are too big...
But wait - because Nylon is stiffer than rubber - getting them into the existing TCA is not easy by hand.
Basically fit them in as you have done - put the metal through the middle of the 2 sides - fit them onto the car and do up the ARB.
You will notice the bushes pull into the TCA as you do them up - seating them perfectly into the TCA and you are then ready to go!
Hope that helps - PM if needed,
Dave
Thanks very much mate.
Had them in a vice this morning and could get them to fit only for them to pop back out when I undid it, so reakon you're about spot on with saying they'll sort themselves out once fitted.
The blocks and bushes are a really good modification over standard items - i noticed the difference immediatly after fitting both.
Go easy on the first outing - get used to the new characteristics of the way the car handles and you will see what i mean!
Dave
