Anyone done a colour coded bumper for the mk3
herd that you have to use proper fine sand paper/ wet n dry,
then primer
then the paint
then laquer
Is that it????
Any tips
  • Replies 16
  • Views 2.3k
depends what finish you want?
half code, full coded? smooth, bobbly?!
if your happy with the texture of the oe bumpers just prime with plastic primer (the halford stuff is actually pretty good!), then paint like you would any other surface
if you want smooth, sand the bobbles off with a palm sander, then use plastic filler primer (halfords again!), will will now have to flat it back as it will have gone rough again.
repeat this process till smooth, then paint and do whatever else you feel like doing to them!
make sure you use goo quality masking tape though, else the paint will bleed. and whe you remove the tape, run a sharpe blade across the edge, it will stop the paint from lifting off the bumper.
do I need laquer then if i want a really smooth finish?
thanks for your help
Considering doing this myself. What could i use to remove dumper shine?
laquer will just add shine and protect the paint. bumper shine is a bitch to remove. i normally go with loads of fairly liquid rubbed into the bumper neat, then wash a few times in plain water, then use paint prep wipes.
yeah if painting then wash real well then go over with say white spirit to remove all traces o shine products and make sure it keyyed well mor the paint wont stick
super shine can be achieved by wet sanding the colour coat then laying a clear on top and buffing that afterwards
Just started CC'ing mirrors this morning.
well started on the passenger one, so going to have odd mirrors for the time being!
used 280 grit W+D, then 600 W+D
2 layers of red plastic primer
and just done first layer of tornado red.
might go and take off driver side now and make a start
and some photo's
painted VS sanded
passenger side on the car
Its slightly darker due to only having one layer of tornado red and no lacquer yet!
More painting when it hardens in a week!
<edit>
and them white parts are my cars tan lines!! (body primer to remove car cancer :( )
Edited by Mike_Rigby
wet flat that and then lacquer dude :p and maybe a few more coats of red?
need atleast another two coats of red, but just waiting for it to hardern first before taking any W&D to it!
What do you think of this then?
noice:)
very nice dude :-) i see you approve of ma new wheels too :oops::lol:
looks good but a bit dark. i always use white primer as thats whats used on the car body (i know this as the paint had worn thin in a few places, so you could see the original primer used by vw!)
My primer is different colours, i got white, beige and now dark grey/black was the lasted primer used.
I'm a cool cat tho, others may find it hard to pull it off.
Told you I'm cool:
Edited by kerrly
