n00b question
my radio has decided its not working anymore so hoping just a fuse as blown, except cant find the fusebox
also, is it marked on the plastic near it which fuse is for which like on my old 6n?
cheers
  • Views 1.2k
is there not a fuse for the stereo in the wiring behing the headunit its self because there is on mine
Does you are interior light work?
yeah everything else works when i took it for a drive last night
battery has been flat for about 2 weeks before though???
Well it's gonna be blown fuse in your fusebox (which is located under scuttle tray on the nearside next to ecu) as the stereo uses the same fuse as interior light and cig lighter.
As the other person said, check fuse on the back of the headunit
is the nearside the passenger side? lol
I'm guessing its the small box on the top right of the bay?
will try and find some keys to pull my headunit out
cheers for the help
yes that's it, they are the old fashioned ceramic bullet type fuses. Apart from the one single blade fuse in the top which is for the fuel pumps and injectors.
