Orginal Factory Number plates
Hi have the original dealer number plates on my car and they are starting to look past their best so I was wondering if anyone knew of a plate maker who can replicate the design of the original plates. I know you can have your name and such at the bottom but I haven't seen anyone who does dealer plates (oh and the dealer closed ages ago)
Cheers,
Mark
  • Replies 13
  • Views 2.9k
The laws on replacement number plates are quite tight now:
The British Standard
The British Standard sets out the physical characteristics of the number plate. This includes visibility, strength and
reflectivity. The British Standard also requires each number plate to be permanently and legibly marked with the
following information:-
1. The British Standard number (currently BS AU 145d)
2. The name, trade mark or other means of identification of the manufacturer or component supplier
3. Name and postcode of the supplying outlet
This is taken from a DVLA document - http://www.dvla.gov.uk/media/pdf/leaflets/v796.pdf.
Since the original supplier has stopped trading it would probably be illegal to manufacture new plates now with the dealer's details on them.
Edited by ronime
Cheers for the reply,
Does this mean when buying a new car the dealer can no longer put their details on the bottom?
tbh I don't mind it conforming the the 3 points made above just have the dealer logo and details as per the original plate.
Number plate supply is now regulated or "licensed". Only license holders can supply number plates and they must put their own trading name and postcode on the bottom of all the plates that they supply.
It therefore follows that if a dealer has a license to supply plates (and given the number of plates required for new card registrations I would suspect that most dealers are in fact licensed) then the plates that they supply must have the dealers own details at the bottom of the plate.
In your case, the dealer is presumably no longer trading and therefore will not have a license to supply plates and therefore you will not be able to obtain identical replacements.
Edited by ronime
why dont you get then details at the bottom made as a sticker.
Get a show plate (std but with no writing at the bottom) and just stick the sticker on but make sure you have loads of excess clear plastic stuff to put over the rest of the plate so you dont get a end of sticker mark?
Now thats bluesky thinking! :)
I've sent an email out to a show plate maker to see if they could replicate it. if not then the sticker idea might be a good second choice! :)
halfords dont a mate of mine got a set 2 weeks ago from there as she had hers stolen and their blank bar the reg number
Halfrauds eh? They should know better. They will turn out to be an expensive pair of plates when Officer Dibble has thrown in his £30 fixed penalty.
Just out of interest, do you still need to go through the whole V5/proof of ownership shenanegins if you want show plates?
no need for all the v5 stuff for show plates....see my post about the plates, if you choose a legal font etc you should still be okay
Have you thought about going to the dealers? On my work experience with school the dealers made there own plates with there own stamp in it.
IIRC, the original dealer is no longer trading.
Thanks for the confirmation. If the plate is pre-2001 then I think that all you need is the "BSAu154d" legend in tiny print somewhere and being pulled by Dibble just to check that would be pretty unlikely (you would hope).
