rear supercharged badge g40
right anyone who knows a bit about g40's knows that some came new with a small 'supercharged' badge on the rear below the 'polog40' badge.
why some came without one isnt quite known but speculation is for insurance reasons.....
my questions are: what length were they and if yours has an original one can you measure it and whats its position? central to the 'polog40' badge or left or right? pics would be great.
you can buy a good replica small one from awesome gti which is 130mm by 7mm and a large one 200mm by 12mm but i wanna know the correct sizes first.
answers from people who actually know would be fantastic! cheers in advance
dan
  • Replies 12
  • Views 4.1k
i was just about to right this as I've bought the medium size one which looks same as original but unsure where to mount
Jake
Jake
jake where did you get this from? awesome gti only lists two? small and large?
i have an original that i got from a g40 bootlid i bought - defo the real shit, il dig it out and pass on the details of it.
but from the top of my head it was roughly 15mm tall by about 12cm long
they were an optional extra!!! thats it! - you either specced it on the car when bought or you didnt.
KiZ
P.S. and its red
P.S.S. the large ones came on corrados only
KiZ
P.S. and its red
woo hoo a reply! I'm convinced this website is getting worse ha ha.
well i bought one from trim sport in red correct font and i bought the medium one which is 135mm long which is about right.. all i need now is the positioning? i think its sits flush with the right hand side of the 'polog40' one so the 'D' is in line with the '0' rather than in the middle of 'polog40' can you confirm this?
cheers kieran. :thumbsup:
go find a shitty 1ltr polo in a street and look where the "coupe" badge is.
it simply just replaces that badge under the polog40 badge
just eye it up until it looks right.
KiZ
this website isnt getting worse - just that the keyboard car builders arnt guessing at the answers as much anymore
interesting. I was lead to believe that they only came on corrados as i have one which i brought as part of a package (grille & boot badge + supercharged badge). TIme to get the double sided tape out!
sorry yes i bought trimsports middle size as it seemed right still noe sure where to put it tho ...
I've got a supercharged badge on my G40 and it's always been there although I did remove it to colour-code it in the similar style to the Passat and Corrado badges. When I refitted it I put it back in the same place....I'll go and measure tommorow to give you a definitive answer on both size and position. :-)
Right I've done a bit of measuring.....The Supercharged badge is 200mm long and 10mm high.It is stuck under the Polo G40 badge with a 10mm gap between the bottom of the Polo badge and the top edge of the tall letters (s,h and d). The 's' of supercharged is lined up so that the bottom left corner of the s is aligned with an imaginary centre line drawn through the 'l' in Polo.I hope that makes sense,but should mean you end up with the supercharged badge slightly offset to the right of the Polo G40 badge. Peter.
pic? as I'm confused cheer jake
perfect although i ordered the 13.5 mm one not 200. doh! ill see when it arrives may send it back.
well heres mine. 200mm one from trimsport looks bang on. I've played with it a tad just to get it perfectly lined up now too so looks great.
