MK3 Questions
I've had a search around and cant seem to find what I'm looking for,
Looking for the fuel tank size of the MK3 polo coupe boulevard and the location of the radio fuse.
I also found quite a bit of oil on my 4th sparker when i changed them today, any idea what could be causing this? Note this is the first time they have been looked at in over 1 year +
Many thanks
  • Views 1.3k
Radio fuse is number 11 in the fusebox iirc. 30amp fuse. i'll dig my polo handbook out and take a look. I should know considering i've changed it enough times!
Fuel tank: 42 litres
Haynes Manual reckons that Oily deposits on a plug means: Worn bores/piston rings or valve guides.
Many thanks,
Mine didnt come with a handbook, any idea of where i could get one super cheap? otherwise no point.
Is worn bores/piston rings or valve guides expensive to fix/replace ?
my bets on stem oil seals for spark plugs
Many thanks,
I found 1 in a scrappy not so long ago... was in a little Fox that i had the front bumper off.
As for the worn Bores etc.. I'm no expert but it doesn't sound good or cheap lol.
I MIGHT have a spare handbook kicking about. Depends if theres one with all my paperwork. I keep an extra one in the garage for reference. I'll look tomorrow.
