New apex seals for G40-charger FIRST SERIES
Hello everyone,
I just registered to this forum to make an announcement: I am looking for people interested in ordering new apex seals for the G40-charger from the first series (the 500 black ones build in 1987).
I myself have one of these babies in my garage and would like to keep it as original as possible. Right now, the G40-charger needs a total overhauling, including new apex seals. As you might know, these seals are not available anymore - and you can´t simply use those from the later G40-chargers, since the measurements are slightly different (from the first series, the seals are slightly longer and higher).
We checked with the austrian company "Ensinger" who produces the apex seals made out of "Sintimid" for the G40-chargers in the last years of their production at Volkswagen. They would be able to build customized seals for the first series, but we would need to order at least 100 sets from them.
That means, right now I am looking for 99 other G40-fans, that want to keep their first-series VW Polo G40 as original as possible.
The apex seals would be ordered by Thomas from the company "Dubracers" (www.dubracers.de) and will cost something around 80€ - 100€ per set. Of course you will get an official recipt, since Dubracers is a registered company in Germany.
The seals would be made out of "Sintimid 8000" and would have the following measurements:
  • displacement device - approx. 356 - 357 mm length, 4.0 mm height, 1.5 mm width
  • shell - approx. 535 mm length, 3.8 mm height, 1.5 mm width
If you are interested, please send me an Email to G40iger@web.de, writing your name and how many sets you would like to order (in case you want some more for spare). Don´t worry: This ist not a binding order yet, I first want to check if we can find enough people to place an order in the first place.
I will keep you updated on how things are going and if we found enough people. Right now, I already have peole signed up for 8 sets (within the last 24 hours).
Thank you & greetings from Germany
Fahrvergnüger
  • Replies 12
  • Views 2.1k
i dont want to piss on your bonfire but i cant think you will get more than a 5 off here, if that!
good luck tho, i cam imagine the struggle your'e having finding parts!
plus the fact that later apex seals are supposed to be better (beige ones are the best) or why did VW change them!!!!!
Yeah but they won't fit, he has a Mk2 Polo G40 I think and thus it has a different supercharger.
ha ha.. great stuff but seen as there are like? what? 2 possibly 3 mk2 g40's in britain iirc and them all wanting a set? and he needs 100 people...gulp! good luck though :-o
getting stuff for g40's is starting to get bad enough now for mk3 owners! i think its good if...or they should if they don't be asking for proof of g40 ownership before dishing out parts to everyone willy nilly lol...i wanted some oem boost pipes...the little ones! obsolete! argg
badges and stuff all gone! but they pop up new on the bay and stuff! clearly people saw potential in them years back and bought a bunch of them lol
Edited by supercharged spaniel
Tav, I'm fairly sure the mk2 G40 charger is near enough the same internally as the revised mk3 version.
Dan, which of those small boost pipes have gone obsolete? I was after a new top intercooler to flat pipe one.
yep that one which is the same as the one onto the throttle body. apparently obsolete. tried to order them ages ago.
Ta, looks like its going to be silicone then.
yeah can youget them in black? and how much?
can get silicone hoses in any colour now, but they aint cheap!
they are on ebay
That´s the reason why we checked with Ensinger - they are the ones who produced the seals for the last series (the beige ones) and would be willing to do a custom made seal for the 1st series (slightly longer and higher then the seals from the MK III chargers), made out of the same material like the stuff used on the last series.
But we need a few more people to get this thing started! (sign up at G40iger@web.de - each one helps!)
I´ve already started this thread in several German forums, in a French one and in a Dutch one. So far, I have 7 people "signed up" within the last 3 days - each one ordering at least 2 sets. That leaves only 85 more to go... :?
Thanks for your support & greetings from Germany
Fahrvergnüger
Hello everyone,
I just wanted to give you an update on my thread:
Until now, 6 people have signed up for the new apex seals. Even though, each of those was willing to order more then one set, this was still far away from the originaly needed 100 sets... :?
BUT Thomas from Dubracers wanted to check with Ensinger, if it is possible to order even a smaller amount.
Answer: YES, it would be possible - but there would be extra costs due to the smaller batch they are doing then...
If we would order 20 sets, the price would be 99€ per set - including a fair 5€ handling charge for Thomas
So, if you now are still interested in getting a set of custom made apex seals (made out of Sintimid) for the first series G40 charger (the 3-piece one), write me an email to G40iger@web.de, including your full name & adress.
I´ll collect all infos & contact information and - if that´s OK with you - will forward it to Thomas from Dubracers, who is going to handle the rest then.
Greetings from Germany
Fahrvergnüger
