Noob.
Alright lads (and ladies)
I'm 17, still learning to drive and currently driving a vauxhall corsa, however I want rid of it. planning on getting a polo because I recon you look like less of a chav when its lowered etc.
I'm thinking of getting a mk4. 1.4CL
My first question for the forum is how are the bump strips attached to the shell? Is it a case of pulling them off and getting some adhesivey shite off, or are they attached with some kind of fixing that will leave holes to be filled etc.?
cheers
  • Replies 8
  • Views 1.3k
Hi there
Can't help with your question I'm afraid but thought I'd come and say welcome to the site :-D
Welcome
they are glued on!
welcome, at the top right of the screen if you are on scrolled to the top you should see the search function button, use that and search for removing mk4 side strips, and also you may want to remove the rear badges use the search function in the same manner to find the info.
yer just use a hairdryer and a credit card and remove them slowly, very simple job if you take your time and dont rush it.
Welcome to the site, good choice of new car
The bump strips are just glued on all you need to do is heat them up with a heat gun or hair dryer and thread some fising wire behind the strips and carefully pull off the glue, then you can get the glue off with tar remover or petrol
hit the nail on the head :lol:
Ahhh cheers for the replys, really helpful :)
