uprated gearbox
where could i get a dog tooth gearbox for my gt, it going in to get some work done but my gearbox isnt going to be able to handle the power so need something a bit better
  • Replies 9
  • Views 1.7k
mk3 gt? gearbox should be able to handle quite a bit, you won't need an uprated one. what you having done to the engine?
Stick a G40 one in
Stick a G40 one in
Same gear box really, different ratios so no more capable of handling power.
Dog tooth gearbox = a bit too hardcore
1. Do you understand what dogs are?
2. Why do you think it will make anything stronger?
3. Spend the money and get a big block gearbox converted to fit the small block.
Crikey! What you having done to it?
BTW, when you find out how much a dog box is (and the awful noise they make) I think you just might change your mind!
i think they sound class!
Are they not actually weaker due to less surface area being in contact with other gears?
Sorry, gearbox noob here, just something I "heard" :roll:
Dogs have nothing to do with the teeth of the gear, they are used to connect the gear to the shaft instead of the synchroniser hub. The reason they are used in competition gearboxes is the speed of engagement. They also wear out quickly and need replacing regularly, hundreds of miles, less if hammered. As half of the dog engagement is the actual gear, it can become very expensive. The noise that people are referring to has nothing to do with the dogs either, it's the whine of straight cut gears. These whine because they are not as stiff as a normal helical cut gear in a road car. STRAIGHT CUT GEARS ARE NOT AS STRONG AS HELICAL CUT. This is because they have less depth, and therefore less stiffness, which is why they vibrate and whine. Straight cut gears are cheap. A straight cut hobbing tool cost £7k last time I talked to a gearbox manufacturer. You need one for each gear, that's 10 for a 5 speed box. Lots of money to invest for a niche product. The same tool for a helical cut gear is even more. If you think of how many road car gearboxes are made then the relative cost is peanuts. The effort put into tooth design to reduce noise is huge. If you want to make a gearbox stronger, you need to make the gear diameter larger and move the shafts further apart. Think force x distance. This is the root of the problem with the 085.
reason i need uprated is because i have had nothing but problems with my gearbox for the past week not being able to get gears and getting stuck in them and then the other day i lew my dif to bits, and it is suppose to be getting turbo'd
