polo G40 1341cc conversion 170+bhp
I have decided i really need to sort myself out and sell anything that i dont use and i want a quick sale if possible.
http://www.edition38.com/forums/index.php?...amp;hl=1341+g40
the thread above shows the car and the spec.
the only difference is that the car now has the original front seats, steering wheel and gear knob other than that it will be as it was.
the car is currently out of mot and is sorn, but i will put a new mot on it in the next week or so so it will have a nice fresh 12months on it.
the car has only done 8000miles max since the engine and alot of other bits were replace with a no expence spared rebuild. it cost me 9k as it stands.
the bad bits.
the front end is stone chipped and the n/s rear arch needs a bit of paint where its bubbled from the wheel rubbing the arch when it used to have the 20mm spacers on the rear.
also the gearbox is fully functional and dosent grind, out of sheer peace of mind it could do with a rebuild although not urgent.
I'm willing to answer any questions.
I'm asking £3750 to start with 12months mot but I'm open to offers as i want a quick sale and i may be listning to deals without wheels etc.
  • Replies 16
  • Views 1.6k
Love this car, But I cannot stretch to that, tho its probably worth something close to that..:(
Shame I guess you wouldn't want a p/x, Mk1 Golf?
sorry no p/x as i just need the money although i am open to offers especially if its a nice simple cash sale
cheers
link not working!
Right I thought id make a list of all the bits I have bought to justify the 9k I have spent on the car.
Breaks.
Genuine front discs pads
Mk2 rear disc conversion
Psd custom braided lines
Ap bias mounted next to the center console and all rear lines run under the carpets
22mm master cylinder
All new copper lines
Suspension
Fk springs and shocks
Vw rear beam bushes
Powerflex tca bushes
Gladersite front abr solid mounts pull the front wheels into the correct position once lowered
New topmounts
Fuel system
Genuine vw lift pump
Genuine vw pressure pump
New fuel tank
Green injectors
Exhaust
Bastuck 63mm stailess system
Psd 4 branch g40 manifold
Genuine vw lamda probe
Engine
fully rebuilt bottom end with psd 1341 pistons
lightened flywheel
newman cam
red injectors
fullblend charger
toothed belts
psd filter kit
removed boost return
homemade catch tank.
gt inlet manifold
psd 4 branch manifold
bastuck exhaust system.
helix paddle clutch.
stand alone oil supply for charger
oil cooler
51mm throttle body
psd custom remap
uprated drive shaft
shell
seam welded chassis leg with additional strut next to gearbox mount
65x65x5 mm alloy front radiator brace stiffning the front up
Respray in original candy white
Badges removed from the boot
Chinese spec door handles
No sunroof
New genuine n/s wing
New genuine slam panel
2x new genuine headlights
Revolution rfx 14x7
I'm sure there are plenty of more bits I have forgotton to mention but if anyone who comes to look at it there quite welcome to look through the heap of recipts I have for it as I have about 99% of them
I also forgot to mention this is a genuine g40 and not a conversion
link not working!
you may need to be an e38 forum member
link not working!
Yup you do, so you should just go on and click 'edit' then copy and paste your original posts on here to save people signing up.
link not working!
its not a for sale link its a bit of a build thread with some old pics.
I'm going to get some new pics just after shes had the new mot
This car is stunning saw it when I collected a gearbox the pictures really dont do it justice. I'm after a 51mm throttle body if your willing to swap it for a standard one and some cash?
Edited by g40lew
great car seen this at no-rice at fleet wish i had the cash
Edited by Daryl
cheers people.
no the car will be staying as it is so no swaps especially when the car is custom mapped in this exact spec :-p
FREE BUMP,
love this..............
Edited by 9OLO
In 2006 you said the gearbox is like 'stirring porridge' and now you recommend a rebuild, whats going on there?!
I assume he means that the gear change was sloppy! And now the problems progressed.
the linkage had come loose on the shifter input so it was pinched up and was sorted, but like i have said i would reccomend a rebuild as its the only thing it hasnt had.
i hope that clears that up 8-)
Do you still have the G40 for sale? If so let me know. Also where abouts are you located?
my e-mail: andy_badger2k@hotmail.com
cheers
Andy
