A little rant
just got the tyres on my newly refurbed audi a3 pepperpots, luking grand and everything, then it came to getting them on the car, to do this i forked out almost £200 on fk (VW 4-100, to Audi 5-100) adapters, 20mm on the back 10mm on the front,
this is a pic of the rear
so anyway, i cant wait to show off to my mates that live down the road, get in my car and start rolling down the road, (alot of scrubbing 8-) ) but then i noticed a knocking sound. i thought to myself that the wheels werent on tight enough , and that the powdercoating might had caused the centre bore to change size, making the rim feel snug on the hub when in fact it wasnt. i went back home to tighten them.
then this happend *ching*
thats one of my new fk adapters, minus the thread,, turns out i was tightening the bolt all the way thru the adapter into the backplate, and cos the bolt cudnt go in, the thread came out, :cry:
now what realy gets on my tits is that no where on the website when i was buying them did it say, "u myt need different sized bolts", and another thing, neither my audi or my vw bolts fitted snug into the adapters, they wobbled.
so if theres any noobs out there about to fit hub adapters, make sure you are bolts fit ( length and width) before you are 80 quid goes down the pan :x
oh well, luks like I'm gunna hav to wait a tad longer to get those damn wheels on.
rant over
  • Replies 21
  • Views 2.2k
OOPS! surely you can do soemthing about them though call them up and explain to them whats happened?
Those Audi rims (as nice as they look) are sooo similar to how the G60 steels look which fit straight on!
Might be worth flogging the alloys - keeping the rubber to fit to some steels?
Dave
Bad luck, I'd be on the phone and get them replaced. Never really liked the idea of PCB changing spacers myself and this is why, at least it happened when you tightened them and not when you were giving it some down your favourite road...
dam straight, still think I'm gonna carry on with the audi rims,
gash :-(
you can get shorter bolts.
machine7.com or something.
thanks, but i also need a new set of adapters, :lol: which is sumwhat of a ball ache , ne one used these adapters b4, wanna know if anybody else has had this prob
hmm is a shame but i have to say that is user error really...
with any adaptors, spacers, anything you always have to check on the wheel bolts, shorter or longer!
they couldnt really say you need shorter bolts, as they dont know what wheels your fitting, and that will alter the equation aswell...
If they had of said use sorter bolts and your rims needed longer, you would be now posting saying "why didnt they tell me i needed longer bolts?"
maybe they should have at least made you aware that bolts may need changing...
aye, the buck stops with you i'm afraid.
I've got there 4x100 to 5x130 adapters but you have to use later style wheel bolts iirc
later style wheel bolts?
@dknight, aye i agree, but i'm a noob, and its a shame i had to learn the hard way,
anyway, new adapter it the post, new bolts - ill have to do sum research
I'm not sure id've made the same mistake myself,but who doesnt make mistakes? Afterall,its only thanks to mistakes I've made previously that I'm more careful now.. Shame it was notably expensive in your case,could've been worse as said,but its worthy to let us know - you could've saved face,but just may have prevented worse from happening to someone else instead. :thumbsup:
Yep, I'm with Mikey. I don't think I'd have made this mistake - but only because I'm not a "noobie" to working on cars.
My old saying is "those that have never made a mistake have never made anything".
bit of a noob, kinda shows, :lol: , i myt hav been more careful if i wasnt so damn excited about whipping the bastards on, seems pretty obvious when i luk back, :oops:
but does anyone know why neither one of the bolts fitted snug?, i mean i bort vw to audi fitment adapters, and firstly the audi bolt didnt even fit in the hole, and secondly the vw ones did, but were loose, u could even wriggle them, just dont get it :?
anyway, just thought id warn anyone else thats in my shoes, and has never used adapters b4,
Edited by chrisbin
from pri racing :
Thread guide for nuts, bolts, studs.
It is essential that you select the correct sized nut or bolt for your application.
Type: Nut or Bolt
Seat: Taper, Radius or Flat. Note that a special washer may also feature. In some cases there is a shank where the nut or bolt has an extended section after the seated section.
Thread: Diameter and pitch ie M12x1.5 equates to 12mm diameter and 1.5mm thread pitch. This is vehicle specific and must be checked.
Length: Length of the shaft which includes the total length of both threaded and blank on the shaft.
Hex: 17, 19 or 21mm diameter head for socket/wheel brace.
Head diameter: New tuner wheels have a narrow hole for the bolt or nut. For this application we recommend the Star Slim, Micro Locks, Spline drive and Tuner locks.
Misc.: Note any other specifics such as open or closed ended nut, shank and washers etc.
Remember: The fitting of after market wheels can require a different style of nut or bolt in terms of seat, shaft length (due to the wheel being thicker/thinner where the bolt goes through) and sometimes a narrow head depending on the type of wheel.
The following list is a guide only, always check the specification of your application to confirm.
Hope that helps. sorry for hear about your wee encounter, we all make mistakes, I've made plenty but you live n learn, just glad it didnt end up with the wheel coming off the car or owt too drastic
Edited by grungeisdead
cheers mate, and thanks for the info, but no where on europerformance does it say what width bolts go in the "audi 5-100" side of the adapter, so I'm pretty much guessing
and what does Big4244 mean by later style wheel bolts? :?
Helicoil the knackered thread or convert the spacer to use studs.
As above or just drill the holes out very slightly bigger and use a tap & die set to put the threads back in.
I'd also be careful about scrubbing because you'll rip your tyres to shreds then it'll be another £50+ you'll have
to fork out. We learn from our mistakes eh!
jesus :lol:
Looks like it was more than "scrubbing" :shock:
I think "grinding" would of been the word id of used :-p
hahaha that green gti was fookin decked on 15s, no wonder it scrubbed more than a fat chick in leather trousers
deary me, :lol:
