120+ in 4th in a g40
normal?? and like 72 in 2nd??
  • Replies 21
  • Views 2.7k
Definately not normal, it would have to be spec'd up, a friend of mine's VR6 does 70mph+ in 2nd, Mk2 Golf 16v's do 120mph+ in 4th. I don't have a G40 myself so i can't give accuate figures.
lower profile tyres would give an innacurate speedo reading...
wow that could be a fucker at a speed camera
^^^Not really, the speedo will show you a speed faster then what you really are doing.
What gearbox you running?
Still the speed shown on the speedo will be the same at a given number of revs, it's just your actual speed will be lower.
I'm running 155/55/13's and when I croosed the 1/4 mile line was showing 100 on the speedo but my ticket said 88mph terminal speed.
I recon you could hit 120 in 4th at about 8 - 8.5k. Check Karlos' youtube vid where he shows 153mph(?) in 5th, see what speed he's showing when he shifts up into 5th. I imagine its close to 120.
my GT's speedo will 'say' its doing 115mph in 4th if i take it right to the limiter so I'm sure a g40 could manage 120
^^I have never given mine that sort of abuse! :lol:
:ninja:
Wouldn't know tbh either! usually if I'm going that fast, i'm in 5th (and on a private road of course!) dont wanna stress the gearbox too much.
If you don't want to stress the gearbox 5th is the wrong choice given that it's prone to failing apparently...
I'm sure in most of the G40's I've been in 4th gear takes you around the 110-120mph region and then 5th to about 130-140mph...depending on tyre size/where the rev limiter is. Someone could work it out using the ratios, standard tyre size and standard limiter.
Edited by Tav
I think the 72 in 2nd sounds a bit high for a standard rev limit on an ATV. It's about right for an 8000 rpm limiter though.
:nod:
but remember what it says on the speedo is not what your actually doingwhen at them kinda speeds on the speedo my GT was doing 110 on the sat-nav and as mentioned if it has smaller tires/rims it will be even further out.
Oh. that seems a tad strange! I wouldnt know what 4th gear goes upto as i limit the car to 4k in every gear unless i really need to be making the engine scream! I've been upto 125 (slap my wrist!) but probably as i'm running 15s, 130-140mph is unreachable for me but hey, the cars fast enough as it is.
On a stock G40 you'll see 120mph on the speedo at 6950rpm or so - so you'll need a higher rev limit chip to do that. 70mph or so in 2nd gear is almost 8k.
As RAW said - your wheel sizes will only affect the accuracy of the speedo, 120mph on the clocks will still be 6950rpm whether you're on 15"s or 13"s.
when i had my 13 inch classics on my mk4 my speedo read 120mph when my satnav told me i was doing 90
It's got nowt to do with wheel size, it's all to do with the rolling radius.
The standard size of tyre on a G40 was 175/60/13 if i'm not mistaken and
if you change it to 155/55/13's,when your speedo reads 70mph your actually
doing 64.8mph.
Check here.... http://www.carbibles.com/tyre_bible_pg2.html
well seen as it seems nobody with a standard g40 wheel/tyre and engine has commented i'll make it clear that my g40 does about 100-110 in 4th 110 really pushing it. 5th from then on.
thats an almost stock g40 circa 130bhp with standard bbs and standard tyres 175/60/13's
dan
Ill get a video up ill acclerate on privates roads
Standard G40 with 175/50R13: http://www.youtube.com/watch?v=PxNpqsNnti0
160BHP G40 not sure on tyre sizes but again gives an idea of gears/speed:
