JUST JOINED THE POLO FAMILY N NEED SOME HELP!
Hi
I just bought a VW polo 1.4 MK4 in dragon green and it has deep scratches :cry: , how is the best was do fill them DIY smoothly?
  • Views 1.4k
Use some Farecla G3 and a buffer if they're small scratches!! Will bring up your car colour well too, then just use some wax!! If that don't work you'll need a bodyshop job cause car paintjobs are about 1mm deep!!
just get a bit of filler, wet and dry it back, primer n spray bk up.
lol u make it sound so easy lol
DIY job can look a bit naff.
the best thing to do is go to a body shop. most body shops charge around £100 a pannel (ish)
and that way you get a nice thick shinney smooth coat of paint. and they usually blend it into the other pannels around it too
Normally any scratch that catches a nail can only be solved with a trip to the body shop. Polishing will help a bit but not remove it totally. If its gone through to the primer then and you are not too fussed about it being 100% perfect then just use the touch up pens.
