i need some help!
ok! my boot wont open! the link cable from the handle to the lock must have snapped or somthing
how do i get to the lock and stuff to release the boot from the inside? argh i have no idea where to look lol
i got a mk5 polo
sorry if this is in the wrong section, i dont know where else to post it
thankyouuu
Edited by chris_polo_gti
  • Views 1.2k
fold the seats down
pull the trim off the inside of the boot and then pull stuff till it opens
Unfortunately its not going to be pretty as there are two screws holding the plastic on.
If you can undo the screws the rest is held on with pop on clips.
Good luck, post your outcomes
thanks!! il have a go in a mo
have you tried flicking the key between lock and unlock quickly and keep trying the handle?
there's a little pin that sits in a 'linkage' that fits loosely between the inner part of the handle which moves between lock and unlock positions. this pin usually drops out so when you turn the key the linkage doesn't move across to the handle so won't activate the catch!
happened a few times to me on my arosa and mk4 polo, i'd try flicking the key first as taking off the boot panel is a bastad and hard to do without the boot open.
good luck with it.
thanks for the info, that method sounds a lot easier than taking everything apart lol
