Mk 5 trip dash help please
hi on my dash the milage shows 42k and under that theres a service thing whiles says service miles which keeps going up what does this mean???
Also do i have a trip button for me to see what milage iv done since i filled up i can press
I press the button under the milages on outer edge but nuthing refreshes the milage or anything
any help be great thanks ryan
  • Replies 9
  • Views 1.4k
It means either it needs a service or the service interval hasn't been reset after its latest service. To reset it hold the trip reset button down, turn the ignition on, turn it off, turn it back on again. Once its reset the "service" flash up will go away and your trip computer will be back :)
hi iv tryed this and dont seem to be working its a late 2000 model if that helps at all ???
Aye seems my method wasn't quite right ^ meh close enough :lol:
yes it will work, you have to hold the button down for a long while!!!!!
it says on the thread above that the mk needs to be taken to a garage ?
so dont think holding it down will work i will try
where and when should i hold it down for longer #
If you press and hold the trip reset button and turn the ignition on, and keep holding the button!
held it down turn ignition on and held it for ages still never came on does this mean i'll have to take it to a garage for them to reset it for me ???
try, holding the button turn ignition on, then turn off, then turn on and keep holding the button for ages again
