Really Low 6n's
To all of you who are concerned please read on....
Just wondering with your cars slammed what you have done with the under tray? have any of you taken it off as you can here mine scrapping the road when i'm on country lanes.
have any of you had any troubles with hitting your sump?
also have any of you taken out your front wheel arches?
thanks
  • Replies 29
  • Views 3.8k
thanks
my under tray is still intact although has several big battle scars, i know foxie runs no under tray!
my front arch liners are currently out, but only for modification, they will be refitted as the edge that meets the do looks unsightly with no plastic there!
i also have had to stuff the a/c vacuum reservoir in the engine bay as this normally is attached to the drivers side inner arch liner! i have tucked it in th scuttle panel for the time being, but i can hear it knock my wiper motor when they are on so wont be staying there!
i have had my arches rolled so there is no inner arches they have been sealed up tho, i like chrispy have a few batte scars but it doesn't seem to do too much damage!!
that was going to be my next question... you read my mind! cool i'll relocate mine when i take the inner arches out
my only worry is hitting the sump and oil pissing out everywhere. just on the off chance do you know how much space there is between the under tray and the sump?
didnt have any of the above issues with mine, allthough i had the O/S/F drive shaft hitting/rubbing on the chassis leg, so had to raise it 10mm, sorted now
I'm running no undertray just now due to it getting so much battle damage it broke off, but have not hit the sump or exhaust or anything once!
Only thing is I tend to get bottles and coke cans and stuff that kind of height getting dragged by the suspension arms i think. Soon gets shot out the back though :)
my undertray is on, but has some nasty scratches, its nice to know its there tho.
you got Akon in the 16v then?
if you whip off the pipe from the vac reservoir feed the wire back up into the engine bay you can relocate the reservoir where you like, i think if i simply tweak where it currently is in the scuttle, it will not knock on the wiper motor when in use
i broke the undertray off on my old mk4 off and it was standard ride height
rally abuse ftw :lol:
I was running as standard but the arches have a few scuffs on the drivers side, the splitter is absolutley f*cked- the undertray was ripped off over an evil speedbump and i havn't dared look at the sump - theres still oil in the engine though and isn't going anywhere.
There's a few inches between the sump and the undertray. The under tray won't do much to protect the sump though if you hit something hard, and if you do you'll know about it :lol:
I've removed mine because it was battered and it means I don't get plastic Sprite bottles or Royal mail sacks caught under my car anymore now.
I can't refit it now anyway cause my air horn is in the way :lol:
took mine off, was battered anyway and doesn't actually do alot (in the haynes its described as a "road noise deadener" lol).
mines shagged, bloody expensive they are too! £70 odd from VW, who i believe are the only peeps that sell em...
My problem with scraping is the Cat, lowest point on the car.
theres about an inch between the cat guard and the actual cat so you should be fine on that.
Undertray's are for gays :lol:
i am going to >one day< make a skid plate under the engine..
what is worrying is the fact that my drive shaft rubs against the frame of the car, under hard turns.
a while ago, it wore the alternator cable which ran along the lip of the carter pan totally through~!!!!
anyone else have this issue?
It is not the sump you need to worrie about
this
leads to this
When I used to park outside my house, and pull up onto the curb, (from those like mini curb ramps) my car used to be like fulled rested on the ground, like wheel almost off the floor heh
After a while it stopped doing it (which is probably a bad sign)
:lol: yuuuurp
i was wonderin about the under tray cause i always catch it....and especially when i go to work as i work on a building site lol....hits everything! i usually drag bottles and cans around aswell....and the ocassional road kill :-S
Edited by Dub Life 7
yeh sub frame sits dangerously low, even more so with the 16v's due to the arb.
technical haynes manual strikes again! 3 spanner rating to remove, KEEN DIY MECHANIC :lol:
mine is riddled with scars now! i kept it to keep the engine clean but it not sits on the floor when i pull onto my street :?
think i may whip it off!
The previous owner of mine removed it, think it had plenty of abuse sitting 110mm lower. I was thinking of getting one to keep the bay clean cos i've had to raise it :oops: Still wondering if it'd get battle scars sitting at 70mm?
I ripped mine off when I did an oil change. bastard fiddly things they are. Not sure If I'm gonna put it back on. perhaps one day...
Mine it battered but then its still hanging on......just.
