Mk2 bits. Free if you COLLECT.
Removed from a D-reg 1272cc Polo Ranger.
The list is approximately as follows:
►Alternator ►Both headlamps ►Both rear light clusters ►Instrument cluster
►Door mirrors ►Radiator with fan ►Suspension top strut mount (Brand new, bagged)
►3-spoke steering wheel (large splines: I had to find a 26mm socket for this if I remember correctly) ► One rear shock absorber brand new, boxed.
►Wiper motor ►Horn
►Rear wiper motor ►Fuel pump (and a replacement fuel pump, brand new, boxed)
►Ignition barrel and key
Edited by grumbler
  • Views 831
►Alternator ►Starter motor ►Both headlamps ►Both rear light clusters ►Instrument cluster
►3-spoke steering wheel (large splines: I had to find a 26mm socket for this if I remember correctly) ►Control stalks ►Rear bumper ► One rear shock absorber brand new, boxed.
►FULL SET OF WINDOWS: Windscreen, rear screen, rear seat windows, front windows with winder mechanisms, quarterlights but no rubbers.
►One wheel with tyre (passable as spare, may even be better than that). ►Wiper motor ►Horn
►Ignition barrel and key ►Washer bottle with pump ►Handbrake lever ►Eyeball vents
►Radiator grill/headlamp surround ►Tailgate gas strut ►Fusebox ►Air cleaner assembly
I want the space back in my garage and this lot will go to the DUMP on July 3rd unless someone can collect from Didcot.
Next weekend is TOO LATE - DO IT NOW!!!!
pm'd mate
Still got these parts or have you tragically dumped them? I'm after the mirrors.
Rich
how much for fuel pump?
