strut braces
hi I'm thinking about cutting the metal plate that supports the back seats of my loon out and i was just wondering if i need to get a strut brace for the back springs or even if there is one made for the back i was just asking to see if anyone has done it already or would know what to do please help thanks
  • Replies 13
  • Views 2.2k
Stevie has done this on his loon and he didn't need a strut brace. But as far as if there is a strut brace for them i don't know, sorry. Hope that helped :-D
kooly cheers myt give it a go then lol
I wouldnt do it yet mate wait till my car gets back form the MOT i will give it a small thrash to see iff my rear window flexes and smashes ..
I am also getting some rather loud noises coming from the back of the car ..
The car will be back with me on thursday hopefully and i will have to have someone sit in the back as i drive down the road to see iff it is the rear window rattling like a mofo or somthing else .
Hopefully it is somthing else though . :?
I should think it will be alright tbh though
just wedge a scaffold pole in between the struts ;)
was just abouts to say the same
but if iirc you can get all three; back, front upper and lower for about 30-35 quid each
Upper rears dont do jack all apart form (look good) matter of personal opinion
Iff anything wehn doing it to the back of a mk2 loon that has had the rear seat arear cut out you need to support the underside of the rear window as its resting on basically naff all .. :?
cheers stevie pm me with results please cheers
so baisically an upward window brace would be the need from floor to bottom of window yes?
The rear window should be fine,the rear panel should hold enough torsional rigidity to stop the window frame twisting too much. An X brace in place of the bench panel would return any loss,but possibly defeat the object.
What is the objective,anyway? Why remove the panel?
i agree unless you had it done in some aircraft grade tubed alloy (pollished) which if your local to derby my mate can do with no tax for mr brown so cheap as chips :-D
Removed the panel as i diddnt want any rear seatgs as i hardly ever carry passengers ..
I also needed the room in the back .
Something a bit diffrent too you know .
Regarding the bloke with the bready .. you should be fine as you dont have to cut anything out ..
The rear window rests on what can only be described as two thin sections of steel / the "parcel shelf" area ..
Piccys ..
Before
After
This is from behind looking through the boot you can see the window is sat on a small strip of 2 pieces of steel that are spot welded together .
I will have my car back next wed and will take for a spin and let you know iff the rear window decides to fall out when i give it some around a roundabout .. :? To be honest i think it will be fine as the seat back dosnt look too suportive .
i presume youve tidied up that cut stevie? that looks abit balls tbh :p
:lol: Cmon man who do you think i am a shoddy mofo ..
Its all smoove .. But its going to be carpeted now 8-)
Its all good having the back cut out .. After 5 hours of driving and giving it enougth beans around a roundabout to make the backend step out the rear window hasnt smashed ..
The Car also feels really stable and rather agile .
Handles really well on the lowering kit :-D
Id say go for it in regards to cutting out mate . :thumbsup:
