Old style VW key
Is there anyway of making my old stlye vw key into the newer ones? Mine looks like a door key but I want it to be a blade key. ANy ideas?
  • Replies 10
  • Views 1.8k
Look on ebay dude.. you can get those flick out ones ;)
I have a merc one that you could have for £20 delivered... ready to put your key in
Me too does anyone no if my p reg key will go into a blade key thingy? :?
This is what my key looks like: http://farm1.static.flickr.com/127/4304715...pg?v=1174581750
How can I turn this into a flip one? I cant just use a blank blade can i?
Yeah I've got same shape key I'm sure I've read of someone on here nockin the pin out of a blade key and puttin that type on there
Edited by Ian.Southall
Yeah just buy a blank flip out one from ebay or similar, then get it cut to your keys shape.
i put a flip 'fob' onto my mk1 golf key, tapped the pin out of the flip key and removed the blank blade, took my SPARE key and cut the plastic bit off and filed the bit that goes into the flip key to match the blank and put a groove in it where the pin holds it in place, popped the pin back in and it worked a treat!
fot the later keys you'd obviously have to remove the chip from the original (before you cut it apart) :lol: and fit it in the mk4 golf/flip item.
so for the mk4 keys do you have to tap the pin out or would an ordinary blank blade from a newer key fit in the locks anyway?
Bummmmmp
I suspect it would be a possible for a locksmith to turn a flip key blade into a old key suely?
