feeler 2xmattigs 13x7 w/ 175 50 13 dunlops
hi,
just a feeler really, just bought a set of mattigs from philj on here, only thing is that the front wheels when fitted appear to be wider than the rears, so if anyone has got a pair of weller/mattigs that are of the same style as mine and was after 2 13x7 would you be willing to swap
Cheers DmO
Edited by DmO
  • Views 415
how much u selling um for and where u from
Hi mate it sounds like you have the typical set up of 4off 7x13 wheels, two with et 20 and two with et 0. if you want to or need to swap for a second narrower pair I can help as I am looking for two 7x13's with a low or minus et. PM me if your interested or need further information on et's. Basicaly et is the amount the wheels stick in or out. The higher the et the more they stick into the center of the car. ie a 7x13 et38 wheel will stick into the wheel well and the same size wheel 7x13 with a et5 or et-7 will stick out of the arch ............ clear ? If your interested I have two et20's freshly powdercoated and am willing to swop for et0 or et-7. Regards David
Err check on the wheels and see what et it is...
Generally to get them to sit even, you'll need a lower offset or wider rear wheels....
Sorry for not mentioning,they are all of et 20 , I'm not implying that they are of different offset, its just the fronts sit further out of the arches, giving the illusion of them bieng wider, , but yeah I'm intrested in a pair of 6x13 s ,if your intrested the et is 20
Only reason I'm thinking of getting a thinner pair is simply to sit more evenly, don't want to space the rears because i think they sit just right
Edited by DmO
what car did u have them on did it rub the arches and standard suspension or lowered
Hi mate, mk2 coupe, lowered 60/60 , not rubbing atall, I'm looking to swap rather than sell
Dmitri
k well if u cant swap pm me ok
