1.8 8v / coilies / brakes
hi guys,
havnt been on here in ages but id just like to ask you guys some advice.
- i have a mk2 breadvan polo and want to get some more out of it... i have a friend who has put a 4.5 auto jag engine in his camper.. he is a quality mechanic...
how much work would it be to put either a 1.6 8v driver or 1.8 8v golf engine in?
- also fit coilovers to help with the wieght ..... also new roll bars...
- what brake up grades on 13" wheels
any sorta help/advice would be great.
Dan
  • Views 1.4k
If your mate is putting a Jag engine in a camper then putting a 1.8 Golf lump engine into a Polo will be a piece of piss :lol:
It's not the easiest conversion, but he sounds capable!
On 13" wheels the G40/Mk1 GTI brakes are normally the best plan unless you get lucky and your 13s can clear 256s.
-i have some 13" bbs wheels on at the mo so ill try mk1 golf gti brakes... Are the hubs the same??
-also can i get coilies for a mk2 breadvan?!?!?
Dan
Edited by DanWestwood
coilovers are available but not exactly cheap, most affordable place i've seen them is Polo Performance Services
Would probably be easier to fit the 1.4 16v out of a Mk4 Polo, given that you'd only need to make minor changes to the mounts...where as those bigger Golf engines would require a sub-frame of some description to be fabricated?
