GT 3F engine parts
Since my block snapped I'm putting the pistons and oil pump up for sale - the pistons raise your compression, essentially giving you a 3f block. They have done about 25k, as has the oil pump.
Pistons are still on the conrods, and have the end caps - £35
Oil pump with chain - £25
Crank pulley with bolt, ideal if you need to swap one pulley from later/earlier teeth - £10
Oil breather modual thing that fits the back of block - £10
I'm open to OFFERS on all of the above and can also post for you at cost.
I'll take paypal.
Edited by twin40racer
  • Replies 10
  • Views 614
hooops
would the 3F pistons fit in the Carb'd HH block (i think that's what i have)
I'm not sure, they will definatly if it has a hydraulic head, but if not i'm not certain. BUMP
hhhjjsmsms
no offers for me?
Nobody for higher compression?
sorry can confirm it's an MH engine, any clues as to if they will defiantely fit or not?
hello... how many miles has the oil pump done please dude... :-)
cough, cough.
hello mate, do u still have the bottom block. I'm in need of the loacating dowels that align the head gasket. the little rings. thanks
