Mk5 Polo passenger side mirror removal and refitting
How do I do about it?
Cheers guys
  • Views 1.8k
remove door card.
unscrew tweeter cover
undo the 3 bolts holding the mirror.
mirror comes off.
unplug wire inside the door.
pull wire through
mirror off
then reverse to put back on.
Ah okay cool, how does the door card come off? I need a passenger mirror the same colour as your car I think, do you know anywhere?!
Clips all the way around the door card, and if you pull the inside handle and put a screwdriver behind it, you will pop off a cover from the grab handle revealing some screws. It is really simple and doesn't take too long at all.
As for getting a mirror in a certain colour, look at scrapyards or for cars breaking on ebay. Or alternatively just get it re-sprayed. Surely won't cost that much for a wing mirror re-spray.
