Mk3 Coupe Breaking
Hi, decided to break my coupe due to a bent chassis leg.
It's fitted with a 1.6 AEE engine, running on GT managment. (Had to modify the inlet to fit, not a great job but still goes well).
Engine with modified mount + inlet, G40 injectors and GT loom, changed the headgasket and cambelt ect before i put it in just under a year ago - £150
Also have another unmodified GT inlet manifold. - £30
Front yellow Bilstein shocks with uprated golf springs.(complete strut assemblies) - £100
Or Front bilstein shock inserts only - £80
Rear G max shocks - £30
Recenctly new bottom arms with powerflex bushes. - £30
Front golf gti calipers with standard discs and pads. - £35
Rear Mk3 golf gti calipers/stub axles/ standard discs and pads. (bearings changed recently) - £45
Anti roll bar with uprated poly bushes - £20
Rear late spec lights - Provisionally sold
Almost new petrol tank - £20
Most other bits available, though the interior is no good, and the arch trim and bumpers have damage to them.
All prices are without postage, I'll have to find the postage price out for you
Cheers, Rob
Edited by robg88
  • Replies 27
  • Views 1.6k
Are the sub frames on the front seats ok? thats all I'm after you could bin the rest! Price posted?
Sorry don't have any seats or frames, the only useful part of the interior is the clock set really.
Lol fair play, cheers for the quick reply!
Hi there,
I am looking to pinch off of you...
Front and rear bumpers, front drivers indicator (clear), drivers side steering arm, centre consol fascia, front grille, drivers side headlight.
PM me asap to let me know what you can do.
HeidiGT
how much for your clocks posted, i need a rev counter thanx
how much for the roll cage?
Make me an offer on the cage, because if i don't get a decent price for it I'll keep it and modify it to fit another car.
price on engine and ballpark price for cage duno if i should offer 50 quid or 500 lol
Hi mate, do you have any decent body panels, cant quite tell what colour it is in your avatar, do you have a code for it.
Ta Rich
It's been resprayed since then in orange, have body panels except for the bonnet. The tailgate has been smoothed but there's a very small crack in the filler.
how much for both wings posted??
how much for passenger side late spec rear?(one with reverse light)
Rear lights are provisionaly sold.
Would sell the engine for £150 with the loom, dizzy, ecu, golf gti afm, and modded inlet and engine mount. The ignition timing will need setting up on it.
Driver side wing is no good, £15 + postage for the passenger wing, the antena hole has been filled and smoothed, I'll find out postage price tomorrrow.
Cheers, Rob
Hi mate i need this bit.
With the little rod in the door that goes up and down as mine is missing.
Mike
Hi how low are the rear shocks ?
How much for both wing mirrors posted?
Rear shocks are adjustable with 7 grooves and a circlip to move the spring plate up or down. I'm pretty sure the top groove is standard-ish height and then each other groove is around 10mm apart.
Some of the paint on the wing mirrors where they bolt to the door has peeled off , but apart from that they're fine.
£15 posted for the mirrors.
Cheers, Rob
Mike
Still need this Rob, let me know if you got it please.
Mike
Are the "Recenctly new bottom arms with powerflex bushes. - £30" standard type or G40 type? Do they have powerflex inner and outer bushes?
Price posted?
cheers
Do the front calipers come with suitable carriers?
Have the door lock thing, £8 posted.
Bottom arms are standard GT ones, they have inner and outer poly bushes. But one of the bushes has split on the lip, I'm pretty sure this doesn't affect it though. £40 posted.
And calipers have carriers, only problem with the calipers is they have different sized bleed nipples, but this doesn't affect the difference in braking forces.
pm'd
Yo...
Still got the engine?
