Paint code?
Hey, i'm knew to all this so sorry in advance for any new person errors i might make :-D
Anyway, I have a 1996 polo and I can't find the paint code for it: i need to sort out a rust problem and so ill obviously need to get an exact match for the paint. I was expecting to find a plate with a number on it but can only find the one on the right under the bonnet which doesnt seem to have much on it :? Can anyone help?
  • Replies 10
  • Views 1.8k
MK4 is in the door I believe.. someone else will prob confirm.. or post a pic of you are car and someone will prob work it out ;)
try the spare wheel well, mine is there but its a 6n2
Yeh only the 6n2 had it in the spare wheel well.. Thats where mine is ;)
I'm sure its like drivers door?
next to the spare wheel well on the left should be a sticker. or take the vin number to vw and theyll tell you
it should be on the inner plastic bit when you open your boot, thats where mine is
thanks to all for you help
i found it. mine is on that bit inbetween the boot floor and the boot door. :-)
good look with a paint match ;) lol
you'll need to blend to make it look like it matches ;)
Try the service manual which has a copy of the VN plate in it.
All else fails ring up VW, give them your number plate and get them to tell you. :-)
I hava a mk4 1996. My paint code was to the left of the spare wheel. Its something like LD5D. If yours is a puple/blue then its the same and if you want halfords to make some then tell them its Shaggalblau from VW 1996 :)
my code was in the back boot
