Mk1-3 Chassis leg 'tubbing'
Considering doing this, seen it done on lupos and mk4 golfs on the net, and sort of at a 'If I'm going to do it I should probably do it now' kind of stage. Wouldn't be chopping massively and am confident we could do a satisfactory job of it safety-wise.
My mk2 which is 70/50ish lowered on 14s has never had any issues with driveshaft clearance. I'll be running coilys and with golf inserts and 6/7 inch sprinngs with 13s or 14s on my mk1 though.
So my question is really has anyone ever had any issues with rubbing, and/or done anything about it on the early polos?
Pics for viewzzzzz
  • Replies 10
  • Views 2.1k
First thing you'll need to do is modify the steering arms in a similar way to what I did, the TCAs will be the first thing to foul!
Next thing will be the driveshafts. Not necessarily under full bump but under full lock, as the driveshaft moves from side to side, and when it's low its extremely close. I had this on mine when slammed as low as it would go (ie pretty much on the bump stops).
As you're going to be having an inch more travel with the golf dampers you may run into full on driveshaft/chassis connection. The best way to notch the chassis legs is to find some 2" or so thick walled tube (steel scaffold with the zinc removed or something), cut it in half and weld it into the trouble spot. You might need to mock it all up with driveshafts in place to work out where the problem area is first though.
Thanks for the help Adam, 'notching' was the word I was looking for really, and scaffold or similar dimensioned steel was just what I had in mind.
Will chopping the struts as opposed to lowering the arms solve the TCA issue though?!
BUMP Anyone actually having problems with driveshafts rubbing on mk1-3s ?
Id pm Rod Stylz,owner of Dr Pepper MK1,though i haven't seen him here for a long time. The rim of his 13s were literally half inch from his front arch when i saw it in the flesh,with the stretched side wall of the 175x50 tucked under the rolled arch.
If driveshaft clearance is an issue,he'll know about it.
my old gt was 95mm down on 13"s only hit the drive shaft when you hit potholes
95mm... :-o you got any pics fo that mate, sounds sat on the floor low!
only one i can find just before i sold the beast to someone on here
was on 80mm shocks/springs with 15mm top caps
with surprisingly no rubbage from the tires but a hell of alot from the road :lol:
Edited by xcore
ohh is that teh one that the gearbox was shot or on its last legs, or you did a box swop or something? i was tempted to buy this actually :p pimp car 8-)
it ate one box so i put another in, then i thought that went(went into gear but no drive) so i got rid and bought a 6n2
My Mk2 down 95mm onthe front only knocks when you go over a pothole too mate .
I dont want to cut a notch in my inner arch though ..
