mk3 boot
right my boot lid has developed a disorder recently so it wont shut unless you really slam it - annoying when you have to get into it at night and wake half the street up! what can i do to fix this.
its a squareback too if that makes any difference.
  • Views 600
The pin that sits on the body, that the catch locks onto, can be adjusted. It should be possible to unbolt. The pin sits in an oval hole, so then can be slid about & then retightened. If you get it to loose though it might rattle or leak water. Trial & error
