painting sills 6n just had them welded
i had both my sills welded up the other day, and they coted them in some sort of underseal a very rubbery texture, and very bumpy, apparntly this seals the sill so I'm not allowed to remove it i just have to paint on top is this true,is their a way i can remove the underseal and use a red oxide primer then paint?????
  • Views 1.5k
not allowde to remove?
aint it your car?
just strip and paint, its just a stonechip protection
Seems to be like they couldn't be bothered doing a good job!
ok but how do i strip the stuff itsd bloody tough
jus get a screw driver an scrape it of if its the same stuf as ours it will come of we use it it ent to seal well it is but also to cover up s**t welding lol u will see if its a good job or not
its underseal, dont strip it of. just paint over the top. Strip it off and you will never make as good a job of re-sealing it and they will rot out again.
