1.5 G40 Breaking.
Right, as a few of you know i have had to cut my project short.
its a bit of a shit descision to make as it was probably one of the better 1.5s
everything is in PERFECT working order and very cery good cosmetically unless otherwise stated.
SOLDfully race balanced 1473 engine, 1w crank, forged pistons, all vag rebuild, lightened flywheel, windage tray, big valve head, ported and polished. 9.5:1 CR matched to GT inlet manifold - £1500
SOLDLysholm Screw type charger - brackets made up for g40 fitting and inlet and outlet in 63mm with pullies. £450
SOLDppp subframe wishbone kit, never fitted - 500
SOLDbrakes stock g40 with braided lines, brembo disks, mintex or pagid pads - 60
exhaust 63mm scorpion system, twin upswept - 175
exhaust 56mm ish longlife, best fitted system iv ever seen, single 4" slash cut 175
downpipe for k03 heatwrapped with lambda boss 300miles use - 75
SOLDbmw fmic with custom lower radiator bar - 50
SOLDblack silicone and alu pipework for ic - 50
oil cooler kit, mocal thermo plate, pirtek hoses and fittings, ebay core 300miles use - 80
rad - brand new couple of fins bent taking off - bugger 300miles use - 30
Helix Paddle clutch 300miles use - 250
throttle body - de wedged - 50
SOLDinjectors 310cc 300miles use - 120
SOLDg40 ecu, loom - 100
PSD turbo base chip 300miles use - 50
g40 dizzy - 40
SOLDcarbon scuttle cover - 50
carbon bonnet - 450
carbon fuel flap - 25
debadge grill - 10
oil pressure gauge with Tee 300miles use - 25
oil temp gauge 300miles use - 20
corrado seats - 50
SOLDcarpetted floor, rear seat and boot area - 30
SOLDmetallic black shell, central locking, trimmed arches and welded in OMP cage comes with rear beam and 1/2 tank of super! fuel pumps, carpet, no sound deadening, dash, NO RUST - 450
SOLDinnovate LC1, never fitted - 100
newmann g40 cam for big boost - eaton/lysholm/g60 brand new - 100
rear lights - 25
g40 rear badge - 30
SOLDf1 mirrors with custom bases - 20
mk4 rocker cover, polished - 40
Edited by currie
  • Replies 16
  • Views 2.4k
hia buddy can you put up a pick of the mirrors or send me one please? thanks alot gaz
Dont suppose i could be cheeky and ask if the suspension is for sale bud???? And if so how much??
Drop me a text matey
Ta :-D :thumbsup:
it was sold to nick but on removal one of the front shocks has been leaking.
will take sensible offers on the suspension. bearing in mind the new cost..
Would the kit come with the struts? I'd also be interested in the rear beam.
Any picturs of the charger???
Tried calling you about this today - still interested as I said in the voicemail.
G40 throttle cable bracket. Its a minor part but if your heading to a post office then I would be much grateful. Must b a G40 one not a GT though
i think i have a spare, if not it will go with the engine as its a bit mean to split
if you do split things
i would like the spring clip things that hold the cam belt cover halves together
hope you get what i ment
cheers jason
What condition is the rear G40 badge in? Any pics? Also did PM you about the intercooler...are you selling it seperate or will the engine be going complete?
Hi
Are the TCA'S avaiable? If so are they genuine g40 items?
Sion
How many rows is the oil cooler mate?
How much for the kit posted?
Cheers Warren
hi, jake, will get back to you tomorrow.
intercooler is 235x16row £85 posted, one of the mounting ends has been cut down a bit, will sort pics.
no TCAS
black 6n, paypal me a couple of quid and il sort you some no prob.
currie what about the bracket for the accelerator cable?
ahaa that too. will all be looked at tonighters! sorry! hectic at the mo!
a mess of a pm sent (or 3). sorry matey
