Stone Chips!!!
After a few long journeys i've noticed my bonnet is covered in loads of tiny stone chips. Is there a cheaper way to remove these than respraying the whole thing? Not got the money atm. I remember reading on here that somone used a touch up paint applied with a toothpick in blobs over the chips, then flatted them back with wet and dry. Would this work and still give a good finish like the rest of the paintwork? or will it be vey noticable?
Also has anyone had chipsaway do any repairs like this? If so how much did they charge you?
Thanks in advance
Neil
  • Views 904
had mine sprayed today along with chips gone, if there only light ask them to buffer them out, it will be around 30 for wholoe, bonnet tops anymore and there scamming you. touch up obvious amte.
thanks for the reply mate. I think there to deep to buff out, they need spraying
