Rear light
Hi guys jus wonderin if anyone knows where i can purchase a pair of rear smoked lights from for a 1.6cl mk4 polo, bin lookin all over the place ad can not find them anywhere, also how much do u think they will be? :-)
  • Replies 8
  • Views 1.5k
you could just buy a can of light tinting spray for about a fiver from halfords or other motor factors, be aot cheaper and you can have them as dark or light as you want...
Edited by neilpaul89
how do u do it? does it look good or naff?
just spray over the outside of the lights. The more coats you give it the darker it will get. They look ok, better than they are standard anyway. If you don't like it you can buy the light tint removal spray.
just remember to put some lacquer over the top once your done to give it that shiny effect
either that or try eBay and your local scrap/breakers yards for 16v/SE rear lights as these are smoked as standard
I tinted mine myself and came out ok
they look ok dnt they? Whats the legal bits and bobs about it with regards to darkness and being CE approved etc
There is no ANSWER to the law side really
basically the law says has to emit same colour light as before and sufficient of it
also reflectors should be uncovered / add additional reflectors
To be honest the main problem with smoked lights is if some little shit runs in the back of you...
all he would say is that he couldnt see your break lights (regardless of how bright they are)... and that could very easily become a 50 / 50 claim or worse.
