Removing Mk4 Polo Window Winders to Remove Door Card!
Just wondering how to remove the winders to remove the door cards guys - can't see an obvious way to do it!
Dave
  • Views 980
Dave
Alrite mate all you do is, Slide the spacer behind the winder out, (this spacer should slide the opposite way to the handle end), then it simply removes from the spindal.
Do u have smoked rear lights?
