Removing Wing Mirrors.
Hi all,
Since I have had my car (Oct '07), I have had scratched wing mirrors, and with my car being Silver and the underneath being black, it shows up quite a lot. I was wondering if you kind people could help me out.
I am thinking of spraying them black.
First things first, does anyone know how I would go about removing them from the car?
Second of all, what type of products do I need to be using, what number sand paper etc, to get as good a finish as I can doing them in the garage at home. Lol.
I will also be using rattle can paint, as its cheapest. I am not expecting high quality stuff, but I dont want too much of a bodge job.
Any advice/tips are welcome.
My general thoughts are to:
- Remove the wing mirror.
- Remove all the silver paint and make sure everywhere is level, no high points with a rough sand paper.
- Use a smoother sand paper to rub it down a bit more.
- Prime the wing mirror
- Sand down, and prime again.
- Sand down again with medium-ish sand paper
- Black coat, sand down, black coat, sand down, black coat...
- Really fine sand paper, then laquer?
Am I somewhere along the correct lines with this, or am I wayyyyy out!? Lol.
Any help is good help, Thanks..
Tom.
  • Views 1.2k
Someone must have an idea!!
remove the mirror
rub it with red hair
prime
wet and dry with 600
paint
wet and dry with 1000
lacquer
wet and dry with 1600
sprayed mine this week, took me a couple of hours and looks mint. there pretty easy to take off, just 3 screws under the black plastic cover on the inside. u need to unclip the top part of the door card to get to all the screws and disconnect the wires.
take the whole mirror and base off, i sprayyed mine all together but if you look underneath there is a cicle cap wich you have to pop off, to get to the screw which allows the base and mirror to come apart (i would spray as a whole looks alot better when on your car). mask off the mirror.
using 600 grit sand down whole thing, you dont need to completly remove all existing paint only make a rough layer for paint to stick to, then wet sand so nice and smooth. wash with warm water and your ready to prime. make sure spray cans are not cold other wise paint comes out in little blobs. spray evenly across mirror and make sur you do reallyfine coats of paint to reduce runs.
2 coats of primer, paint and laquer (i never sanded between coats and still turned out good)
hope that helps
Thanks a lot Josh, dont suppose you have any pics of the finsihed product do you?
Where abouts did you get your paint from?
Ta
got it from halfords.
ill tryand put some pics up later
Nice one Josh. Cheers bud.
Thanks McCann. :)
