scratches?
Hi folks, Anyone know a good place to go in west mids area to get me little scratches out the side of my car? :thumbsup:
  • Views 809
Does it need spraying or are the scratches light?
Have you tried using some t-cut or scratch remover yet? Sometimes light marks can be superficial and a good detailer could polish it out...
Maybe contact a local car detailer and get thier opinion before shelling out on spray work?
my mate got me sum stuff that he uses at fiat for the courtesy cars, its white in colour (thats all i know)
you need a "fine cutting compound"
t-cut is no good as its got ammonia in it and it will fade eventually with use (my old corsa has clouds on it :biggrin:)
id go to a bodyshop and try and blag some off them.
when i got my spray work i asked the bloke, he said the general rule is that if you cant get your nail in the scratch, it will probably buff out, if not, you need to get it sprayed up.
hope this helps.
thanks guys!
