Mk2 carpets rant!
Right, just doin the carpets and holeeeeeeeeey shit they are a pain. What's with those crazy washer type things that u have to wrestle off?! I got so many cuts n bruises from those bastards!!! :angry: :angry: :angry:
And then when you think it's the easy part, you gotta improvise with the nails on a different carpet, surely all these holes aren't good?! :lol: :lol:
I think swappin the carpets in an old polo has to be one of my least enjoyable things ever! One of those mods where you go "why the **** am I doing this?!!"
now, any tips on re-fitting carpets?? :badgrin: :badgrin:
  • Replies 14
  • Views 3.1k
Those crazy washers should turn like a nut to come off, then just push on.
As for the nails, fill the old ones, and make new ones with the original nails and a hammer.
Re-fitting should be a peice of piss really, just remember to put the black covers for the runners back on before you put the seats in, I've forgot until it's too late on many occasion.
Haha yea I got the bastards off eventually! And I will use the old holes with the nails or try to..Gettin there slowly hehe
And yea I forgot the black strips once, never again :lol:
The nails made me laugh,like what did VW do,get carpet fitters out the yellow pages?
I used only self-tappers for the sills,and broke half the metal things for the bulkhead. The later ones are plastic with threaded pins but as the earlier ones are not threaded,they're little use.
Still,at least its not all glued in like the Scirocco..
Yea the nails are a bit pointless anyway to be fair, they can't do a lot... anyway must crack on.... :roll:
I never bother putting the nails back. If I'm getting pedantic, a roll of self adhesive velcro works well.
i swapped carpets over in my mk3 a few weeks ago, i didn't realise until the last few washers that they just screw in! did my fecking head in. only took me an hour to swap front seats, rear seats and carpet so was quite chuffed though!
yea I left the stupid nails lol didn't think about velcro, if it comes loose i'll use a bit thanks for the tip :thumbsup:
I found the washers didn't wanna screw in so I used a BFH and a socket, worked really well
I refitted the carpets in my Mk2 and I can empathise on those evil washers!
I bought an offcut of good bedroom carpet cheap (about £30 or so) and made a lot of measurements of the interior space to be carpetted. Since I'd long since got rid of the original formed felt carpet thing before I started the work (just pulled it out, didn't fight the washers) I didn't have a pattern.
The best bet is to cut a rectangle about a foot wider than the floor pan. Strip out the seats and the centre console and then lay the big bit of carpet in the car. Using a sharp Stanley, hack through the carpet for the gearstick and handbrake. Cut in diagonally from the corners too so that it fits the three dimensional bits, being sure to trim it carefully and join the gaps. A little useful tip is if any backing does show, get a bit of the carpet fluff and glue it over it. If the glue is strong enough it stays put even when hoovered and looks pretty smart.
It takes a lot of fiddling, swearing, head-banging on the bottom of the dash, grazed knuckles and brutalised fingertips, but eventually you'll have it trimmed something like. Then hold it all in place with the door seals and centre console, push the carpet over the pegs that had the washers to keep it up under the dash and screw the seats in. Job's a good 'un.
It can be done on your own, but having a helper is invaluable, if for nothing else than a constant supply of tea!
There are some photographs of the finished article over here: http://www.clubpolo.co.uk/forum/index.php?...m&album=412 I'll be posting some more pictures soonish.
i changed my carpets a little while back, it didnt offend me that bad. the thing that annoyes me tho most is those stupid side carpets that are glued on, so most of my carpets are black, until the little grey bit on the side, looks shit.
haha yea I have the exact same thing. Gonna spray em with some kinda dye at some point I think
just a little tip, if you dont like carpets. never ever attempt to remove/re-fit the covering from a seat
worst decision of my life
I used to take my Carpets / Deats out before shows and some meets to hover it all out good and propper :roll:
I reckon i could strip the full interior excluding dash from a mk2-3 in around 20 mins tops .. :lol:
Practice makes perfect :nod:
  • 1 year later...
HI I HAVE MK2 BREADVAN G REG 1990 WHERE DO I GT A CARPET FOR THAT??
not by shouting at people with the caps lock button,
simple answer, out of another polo. Mk2 or 3, makes no difference on shape or age, floor pan in the same. you have the choice of grey, black or brown. i dont know of any other colours.
start here perhaps
