G40 Head
I've had a problem develop with the head on my G40, and am desperate for another Good one. Please help :cry:
Still needed 23/08/08
Bill
Edited by Billy Boy
  • Replies 10
  • Views 1.3k
haynes is wrong - my work for a while but the valves wont like the added beating / heat as the exhaust valves on a G are sodium filled to reduce the heat when in operation so I'm made to believe.
Getting harder and harder to find heads / blowers and boxes now - keep all 3 V HEALTHY!
Thanks for the info there mate, so presumeably, I could widen the search to include a gt head and fit all the g40 valves????, as the g head is not really bad, it just has a mark between the cylinders causing a weak spot for the gasket.
thanks again
Yep, swap the cam and exhuast valves into a GT head will do it.
good man :-D
still looking guys
up up up
bump
where are you located? i have one
I'm on the south coast but my brother travels the country, where are you?
pm'd
Still looking though
