Painting Help
Hi All,
This is bugging me a little bit now.. My paint work is so crap now.
I want to get it sorted.... How much do you think it'll cost to get this done by the Pros?
Or does anyone have any tips / guides they'd like to share?
I've got me some sand paper, Rubbing compound, all that jazz bar the dragon green paint.
Here some pics... Also note the rust.
Liam
  • Views 774
I'm doing mine myself in a Gazebo!! :lol: Theres soo many factors to consider about DIYing it though, if you're going to consider it you need:
-Time
-Space
-Patience
-Knowledge of assembling and dismantling the car.
Equipment:-
Sheltered (preferably heated) garage, although summer time with a shelter (such as a gazebo) could work on warm days....
Primer 4-5 litres
Thinner 1-2 litres
Paint 4-5 litres
Lacquer 1-2 litres
Sandpaper; rough to very fine
Polish / Wax
Lots of sizes of sockets on a wrench
Screwdrivers
Good bright lights for night work and painting!!
Also by the look of the last pic, you'll need to sand down past that rust and use some rust preventing products and maybe some filler for smoothness...
Thanks for the reply chris.
I think i'll try to look somewhere for a quote...
I seen a guide a while back (can't find the link now)
But, if you prime, sand, prime, sand, paint, sand, paint sand then apply some rubbing compound it looks to be a good finish... then apply the clear coat.
However, the only problem i see in that is the dragon green has small flakes in it... so i guess i'll end up loosing that with that method?
