Milage on mark 4's.
Ok so I've been posting a lot about GT's of late but after many problems with insurance and general condition of GT's I've opted for a mark 4 polo again instead and hopefully ill get a GT next year when i can get things cheaper. thanks for everyones help with that matter also.
I've been searching autotrader and have come across a type of polo known as an "SE". however most of the milages seem to be way over 100,000 all the way up to 128,000 is the largest figure I've seen.
My question is wil lthe car still be worth keeping? i dont want to get it and find the engines pooped in a few thousand miles after the purchase. anyone else had any experience with high milage motors and anything i should look for on the car that might show signs of warn engine and suspension etc?
cheers for the help dubbers.
  • Views 1.4k
If its been looked after mate and regularly serviced then mileage "shouldnt" be a problem
I'm quessing that those high mileage ones have also had replaced gearboxs too so will save you the hassle :-)
Since when was 128k high on a car that is 10yrs+ ??????????
i thought that was fairly high kerrly? mines only got 90 on it. could be wrong though?
sounds like my best bet is to take it for a test drive, listen for ggrinding noises, smoke on start up, obvious oil leaks? etc.
best off just viewing some and see what noises it makes from the engine when cold and warmed up i suppose, n just check all the usual things you check when look at a car and get a test drive in lol
you will get a lower millage one if you keep looking about
The average car does something like 10-12k a year, so an average 10 year old car would be 100-120k. OK, 100k IS a lot of miles, but it's pretty average for a car that old.
Just make sure it's been serviced regularly, ideally with receipts if they've got them because stamps in a book can be faked more easily. Also make sure you know when the cambelt was last changed.
