help 17" tyres sizes for a 6n please
hi can you help I'm looking for a tyre size for 17" wheels on my 6n polo
  • Replies 15
  • Views 3.9k
195/40/17 prob your best choice
you seriously want 17's on a polo :|
That's what I was thinking! :oops:
8-)
8-)
that was what i thought too
but if you want to do it 195/40/16 is the biggest I've seen on so will probly need 195/35/17s
oh and wrong section btw
165/40 is the closest match to standard tyre sizes and will pretty much guarantee no rubbing, 165/35 is slightly lower profile than the original sizes and will help if you plan on going low low low. Apple bottom jeans etc.
185/35s are available and would probably be the best size to maintain a reasonable contact patch, and not be dangerously narrow for the rim. They are also spot on with regards to rolling radiuses.
195/35s are unavailable.
Hope this helps.
ok ill go for 16" it was just i had a chance of a set of bbs rc cheap
Hey if you can get the right tyre size and lower it sensibly I see no reason why you can't run 17s, small wheels are overdone!
Well said...
17's could look good if done nicely
I've only ever seen one mind and it was a bit of a shocker
I have 17" on my Polo. You just needs the 185/35-17 tires and there will be no problems at all ;)
Pics;
Wow.....how did you get 17s to fit??
I tried and failed :(
Now that does look cool, very cool in fact, what size rims etc? are u lowerered ? how much ? and are ure arches pulled / rolled>?
mk4man: You need the right tires! the 185/35-17 is smaller than 195/40-16 ;)
The rims are 7x17" ET35 with 5mm spacer in front an 13mm back. I have lowered it max, abaut 100-110mm. It stops in the rollbar in front now. Light rolled back only. :)
that does look sweet on 17s but where the hell did you find the tyres and what sort of price
Edited by debsgt
www.mytyres.co.uk
Asif
I bet altogether though, it costs a bomb?
