Help depo headlamps fitting wiring loom
guys i need some helpp. I've purchased some depo headlamps like the ones foxie, p20 dub and phillyt have got. I've fitted them but how do i wire them up? i got a loom with it, i understand that theres 2 connectors that go into each one of the light, then 2 terminals go to the battery, but I've got one plug that I've no idea were it goes
can anyone help my cars a mk4 1995 m plate polo 1.3 cl
  • Views 1k
anyone?
the single plug leftover just pushes into the original plug on the cars wiring loom, on any side, drivers or passenger
passenger sides usually best to use as the battery is on the same side
cheers gugs I've found out what was wrong the connector u get on the new loom is 7 pin and my original one is only 4 pin so had to switch the connector around from the original headlamp
