respraying after treating rust
Say for example i have treated some rust in the corner of my door. what i dont quite understand yet is how i sand it down regarding the thickness of the paint surrounding the area I'm going to spray.
what i mean is shall i section of a square around the area, then just smooth and paint that, or shall i just smooth randomly over the area, meaning when i spray it i will have to spray over exsisting paint.
i get scared that if i add to much paint + laquer the levels of the paint between the treated area and the rest of the door will be un-even.
its hard to explain so i have a picture here:
  • Replies 12
  • Views 1.7k
you can't really do it like that without it looking a right mess. You'd need to spray the whole panel, this is what a bodyshop would normally do too.
thats what i was afraid off...
whole panel job...
it could be blended in with those patches but for all the hassle you might as well do the whole thing
post a pic of the actual repair...if its the corner its possible to patch it in
ok listen to my advice, I'm a panel beater.
you need to get a D.A sander (orbital sander) with 400 grit paper on it. you need to sand around the edges of the repaired areas, this will spread out the repair. just keep going untill you cannot feel a single bump shape or anything. this will make each repair look huge, and some of the sanded areas might even join.
when it comes to spraying, dont section off a random part, you need to mask along a swage line ect but it has to quite a sharp swage line esle youll be left with hours of polishing that will get you nowhere. spray the small scetion that youve repaired, then laquer the rest of the door.
i would advise using a gold scotch brite (like a scouring pad, but dont use a scouring pad) to flat the rest of the panel that is going to be laquered, but if your limited for shops just use a 1500 grit wet dry paper make sure you use plenty of water when using it else it will scorch the paint and end up patchy.
make sure your first coat of paint is only thin, you want to be able to see the repair through it still, so just sort of dust the first coat on, then leave it for a few minutes and add a thicker second coat, leave for 10 minutes then add the third and final coat, leave for half an hour, wipe it over with a dry clean peice of tissue to remove any dust or crap thats settled, then laquer.
i kow that alot to take in and if so you get stuck give me a shout on msn, my addy is- sammyt002@hotmail.co.uk.
hope this helps.
on a bonnet it's a full panal job or you'll spot the repair easily when light shines on it
doors i usually paint and blend out from the area but i still clear coat the full panel unless there's trim or very distinc bodylines i can mask / back mask too you don't need a D.A. it's better to do it by hand as you can make channels in the paint with a D.A. quite easily without realising till it's complete
by hand? talk about takeing forever, using a D.A is only for fanning the area out and removing scatches thats why i said use a 400 grit, if it was something like a 180 then you would definattley make the panel shapey.
thanks for the help guys. i understand what needs to be done but due to my skills its best i dont try it myself. I've been quoted 175 for a respray of both doors (where the rust is in the corner)
is this descent?
the price is decent but check there work is ;)
i use abranet sanders da's are only good for stripping paint off no good for shaping stuff and doing it by hand means you can feel high and low spots etc much better results by hand i only ever use a da for flatting the paint off around it if it needs it ;)
Right a DA sander is good for feathering edges out, You prime the area anyway and flat the primer by hand. Theres masking ways to stop painting on everything. If you cant use a DA sadner then dont use one simple as that you will make a mess of it but if you know what your doing it cuts the time by half. You can just spray that area. If your good at colour matching and know how to flick the paint out properly then it can be done on a bonnet without seeing it just a little area. But it takes experiance and skill to do this especially with metallics.
Edited by polochris20
save time in the first place by applying the filler well ;) then u don't need to da and only a few minutes sanding
