stering wheel grinding mk4
anyone got any ideas what it could be sounds as if its coming from between the sterring wheek and the indicator sticks, sound like thier is a lot of grit or sumting in their but it was fine thismoring wen i left it parked up at work and wen i came out it srated doing it??
:lol: your mind talks faster than your fingers, good effort.
It's just some dirt and crud built up on the copper ring. Stick your head behind the plastic front trim and you'll see a copper ring to which a pair of springs make contact. Clean this area with a carb cleaner soaked cotton bud or pipecleaner. The scratching sound will then disappear.
PoloD.
just had a look their was a lot of dirt on the copper ring, but the ring as split which left a sticky up bit which was rubbing just pushed a screwdriver in to flaten it a bobs you uncle, what does that ring do???
It's the contact for the horn wiring.
easiest way to remove a ll the shit is either with a cotton bud and a piece of paper folded up to slip between the contact and the ring.
go lock to lock and it will remove all the grit
