removing an airbag steering wheel
I'm fiting a new steering wheel with boss kit to my 6n, altough it has an airbag steering wheel, will this effect how i remove it?
wack it with a hammer
Ideally you should disconnect the battery before removing the airbag and also you are supposed to get rid of any static charge on yourself by "earthing yourself" in the workshop you are supposed to just touch a ramp to do this. You should store the airbag somewhere out of the way and with the outer surface facing upwards.
By removing the airbag the warning light will come on which is an MOT fail and you may also invalidate your insurance.
Matt
"By removing the airbag the warning light will come on which is an MOT fail and you may also invalidate your insurance.
thats not right.
an airbag lamp on in an MOT test is only an advisory. i think your thinking of the ABS light. cause thats a fail :) but if you take it to any garage that have the computers to get rid of your airbag light its all hunky dory
dissconect the battery then remove the colum surround and look underneath there is a short flat cable about 6inches long this is the one that sets the airbag off disconect it then look on the back of the steering wheel there are two allen key bolts remove them then the airbag comes out
i think the warning light is the one of the switch blanks to the left of the steering wheel just pop it out and remove the bulb so it doesn't light up
i would check that the car will pass an mot without it before throwing it away tho
if it wont it will prob affect insurance if they see the car as unsafe without it {i doubt it tho}
the only way i recon it could affect the insurance is if you dont have a modified policy or you dont declare it
Oh ok I couldnt remember about the airbag light but over here (NZ) its a WOF (MOT equivalent) failure.
I think you would have to inform the insurers as you are deliberately removing part of the safety system from the car which is there to provide protection in an accident. It would definately be worth a phone call to be sure.
If the airbag is removed you cannot erase the fault and extinguish the light as the fault code will be straight back into the control unit as the system does a self test each time the igntion is turned on.
Matt
