pressed plates arent sticking
I'm using the 1 mill thick sticky pads and there shite on my 6n.
they keep unsticking and coming off.
is there any beter stuff?
thicker stuff?
cheers
  • Replies 10
  • Views 1.7k
heavy duty velcro
velcro ftw :)
velcro matey or Focus do some good double side stuff for about 2 quid a roll
if the plate is stayin on that car an u dnt want it off for ne reason then get urself sum no more nails
i used those sticky strips with a tiny blob of Sticks Like Sh*t. they aint coming off now lol
1mm thick is no good, u need thicker. Or if u never want em off, that sticks like sh*t stuff is the best way
where cn i get some of that stuff?
velcro if from halfrauds, i wouldnt use no more nails etc as if you get pulled and made to take them off your stuffed
silicone... its cheap and when you wanna fet them off its easy
Circular self-adhesive velcro pads from Halfords work really well. Also stick some on your normal plates and keep them in the boot for a quick change over if necessary (if u get pulled for the pressed plates)
